PWK 28mm dimensions ?
nellyboyo
I`m away at work at the moment so I can`t measure mine . I`m looking to get a bit of hose to replace the manifold rubber thats giving me problems on my imola at the moment , so can someone give me the ID and OD of a bit of hose that I will need please . :)
I`m sure there`ll be some in a skip somewhere here :?
Yanker
Hi Nelly. The PWK takes the same size rubber as the PHBH: 35mm spiggot on the carb = 35mm ID on the hose/rubber.
The OD is not crucial, I would say that the typicalradiator hode usedhas approx a 3mm wall thickness - so about 41mm OD.
nellyboyo
Awesome, cheers mate....I`ll se what I can find :twisted:
