gp200
mods64
hi all ,can ya run a gp 200 engine on a 20mil carb with 22mil jetin? and carb slid .with af big bore any info would be great .. 8-)
No; the 200 engine uses a different manifold and won't take a 20mm carb. You need to use a 22mm or use a larger manifold for a rubber mounted carb.
goldeneye
SX 200 and TV200 both used 20mm carbs as standard. no reason a GP 200 , with correct manifold and jetting,cant use a 20mm carb.
True; can I change my plea to one of insanity? :D
