will T5 engine slide straight into a GL frame???
markauk
does anyone know if this is a straight swap ??
Svint1
It is.
Just sort the electrics.
President of Roughnecks Scooterclub
http://www.Roughnecks.no
1965 Vespa SS180 (218)
1971 Vespa 90 Racer
1986 Vespa PX250 (250 Rotax on CNC casings)
1987 Vespa PX210 with Cozy Sidecar
Scooterso
markauk wrote:does anyone know if this is a straight swap ??
might need to remove carb and box to get engine in, then put box and carb back on...
also might need longer spacer at top of rear shock, PX engines used the longest spacer.
