will T5 engine slide straight into a GL frame???
does anyone know if this is a straight swap ??
It is.
Just sort the electrics.
President of Roughnecks Scooterclub
http://www.Roughnecks.no
1965 Vespa SS180 (218)
1971 Vespa 90 Racer
1986 Vespa PX250 (250 Rotax on CNC casings)
1987 Vespa PX210 with Cozy Sidecar
1971 Vespa 90 Racer
- Scooterso
- registered user
- Contact:
might need to remove carb and box to get engine in, then put box and carb back on...markauk wrote:does anyone know if this is a straight swap ??
also might need longer spacer at top of rear shock, PX engines used the longest spacer.
- Gene
www.scootersoriginali.com
