t5 rear wheel wobble
Tosh
its only slight,not up and down or front or back,but if you get hold of it from top to bottom its like in at the top and out at the bottom,a bit like an end plate faulty bearing so the wheel tips.what`s solution to the prob just don`t fancy failing the MOT.
Ta Paul
wack 63
Main scooter: '71 GP TS1
It will have slight movement even when brand new or fitted with new bearings.Check the hub is tight (70 ft/lb) but remove first and check the splines and stub where it contacts the rear bearing as these can wear.
Tosh
Thanks wack63 for that will check at weekend
