Quick question please chaps:
I'm using nyloc wheel nuts to bolt my standard rims together & to hubs.
Should I use flat washer, spring washer, nyloc or leave out the spring washer and just use a flat washer & a nyloc?
Cheers.
Wheel nuts
sparklymarkly
- registered user
- Main scooter: Lambretta GP
- Contact:
On my lambretta the studs aren't long enough to use Nyloc and spring washers so I don't bother with a washer at all.
I check em everyday....on all my scoots.
- paulmgreen
- registered user
- Main scooter: Lambretta Group 4 Race 200
- Contact:
Nylon & flat washer I'd say.
www.JPPLambretta.co.uk
- red
- registered user
- Main scooter: Scomadi TL 250 (Ltd Ed No.3)
- Contact:
I use 'Nord-lock' washers as they are less likely to work loose and also use shallow depth nyloc nuts.
Also use these on cylinder head studs
sparklymarkly
- registered user
- Contact:
Cheers all :fb:
I'll ditch the spring washers & have a look at these NordLocks as well.
Thanks.
Thanks.
I use Nordlock washers on my sip tubeless.they seem to be doing the job.
With all the stories about loose wheel nuts lately I'm suffering from wheel nut paranoia..
I never used to bother before,but I ALWAYS use my torque wrench now aswell
