Wheel nuts
sparklymarkly
Quick question please chaps:
I'm using nyloc wheel nuts to bolt my standard rims together & to hubs.
Should I use flat washer, spring washer, nyloc or leave out the spring washer and just use a flat washer & a nyloc?
Cheers.
andy66
Main scooter: series 3
On my lambretta the studs aren't long enough to use Nyloc and spring washers so I don't bother with a washer at all.
I check em everyday....on all my scoots.
paulmgreen
Nylon & flat washer I'd say. :)
www.JPPLambretta.co.uk
red
I use 'Nord-lock' washers as they are less likely to work loose and also use shallow depth nyloc nuts.
Also use these on cylinder head studs
red
For further info on Nord Lock have a look here
http://www.nord-lock.com/
sparklymarkly
Cheers all :fb:
I'll ditch the spring washers & have a look at these NordLocks as well.
Thanks.
andy66
I use Nordlock washers on my sip tubeless.they seem to be doing the job.
With all the stories about loose wheel nuts lately I'm suffering from wheel nut paranoia..
I never used to bother before,but I ALWAYS use my torque wrench now aswell
