need help disc brake leaking
golf19gt
Main scooter: lambretta ts1 230
hi i have just fitted a new scootsrs outboard disc brake have bled it up but is leaking from the top and bottom banjo bolts i have changed the washers but it is still doing it any ideas
My LTH is doing the same.....lol.
I had a similar problem with a used SPAQ diec brake recently. After advice from Mark on here I changed the banjo bolts to shorter stainless ones and some new coper washers both from sellers on ebay. Instant success 8-) The banjo bolts can bottom out before sealing properly :roll: the shorter bolts prevent this from happening.
golf19gt
ok thanks i will try that first
camel
have had similar issues with two of my bikes....managed to cure one by buying new olives on ebay,and trimming the braid back a little further,also i put a dab of hydraulic seal on the threads before i nipped it up.ok thus far
think next time id buy a brake line pre crimped as the thought of dot 4 dribbling over my paintwork(which has happend before)does worry me
Craig H
Use DOT5 won't take paint off but a bit more ££££ but not as much as a respray
