Anti dive
sydduckett
i need an anti dive for my scootrs set-up. questions i have are:
Who sells the scoots rs ones in the uk, looked on Just Lambretta site and dont seem to have any?
Is there a 2nd version (rose joint) of the scootrs anti dive available?
and finaly will other makes of anti dive fit the scootrs set up?
Thanks
Sef
Give Martin a call (justlam) he can sort it out for ye Sef (to turn your scoot rs into anti dive)
col68
Main scooter: lambretta s2 li225 ts1
have you got a number for justlam could do with 1 for s2 .ta col
Corrado on here Col
Sent from my GT-I9000 using Tapatalk 2
tonydevon
Main scooter: '71 GP125
surely for antidive to work properly doesnt the link need to be the same length and angle as the dimensions from pivot to axle?
sorry just my thoughts, Im still building my first scooter, but if Im wrong then it will at least save me some wasted time on my own build, just applying logic and experience building springer forks for chops etc
Craig H
I bought the scoot RS anti dive kit of Corrado £70 I think and had to replace the bearing in the caliper bracket and also the tie bar had rose joints in but were crap so made my own tie bar other than that a good bit of kit
You need to keep your eye on that hydraulic cable Craig, looks like the outer's damaged, it'll cut into the inner cable in time.
Sorry guys I'm out of stock of the anti dive upgrade kits at the minute, likely to be a few weeks before I get any more in stock.
GP Kevo
So, the new ScootRS anti-dive kits are good, have rose joints, but have a crap tie rod? Do I have that right?
Craig H
Its the bearing in caliper bracket and the rose joints in the tie bar, the tie bar is ok. I personnely didn't like the tie bar or the bolt on clamp the goes onto the forks but it does its job just check bearing and rose joints are ok, they do look cheap ;)
dazbo
Main scooter: vespa p200e
last one I bought was a scoots RS one from MB about 3 years ago
