Front brake light switch
Posted: Sun Aug 05, 2012 12:56 am
by rosscla
I just fitted a hydraulic master with a brake light switch, what are the options for wiring it?
Re: Front brake light switch
Posted: Sun Aug 05, 2012 10:47 am
by sparklymarkly
Just run a parallel pair of wires from your rear brakelight switch to the front one.
Either switch will then bring the brakelight on. Simples!
Posted: Sun Aug 05, 2012 11:08 am
by rosscla
Cheers, Sparky I kind of thought that but wondered if there was an easier way...
Progress is slow, it's never dry when I want to work on it...
Posted: Sun Aug 05, 2012 7:15 pm
by wack 63
Take a live feed from the headlight connector block to the switch then a single feed down the frame to the rear switch and join to the switch "out" terminal.
