Front brake light switch
I just fitted a hydraulic master with a brake light switch, what are the options for wiring it?
sparklymarkly
Just run a parallel pair of wires from your rear brakelight switch to the front one.
Either switch will then bring the brakelight on. Simples!
Cheers, Sparky I kind of thought that but wondered if there was an easier way...
Progress is slow, it's never dry when I want to work on it...
wack 63
Main scooter: '71 GP TS1
Take a live feed from the headlight connector block to the switch then a single feed down the frame to the rear switch and join to the switch "out" terminal.
    Users browsing this forum: Ahrefs [Bot] and 5 guests
