While the mrs was out getting her nails done...
soosh
I dug this out of the garage as was keen to see what it sits at on a good road so got the gps out and wound it to the max revs which i was happy to sit at on a motorway/duel carrageway so went up the road and back.
Now i didnt scrimp on quality when i built the motor but didnt buy things i didnt need and didnt go for the "ultimate" kits on the market,its only 130cc but 69mph aint bad as a cruising speed.On the way back i nailed it in 4th but it didnt rev out as good as it can do which was a shame but still 77mph.This motor cost me less than 1k to build and apart from a few teething troubles which was my fault,its been reliable and it runs on good ol Groundsman. :D
soosh wrote:I dug this out of the garage as was keen to see what it sits at on a good road so got the gps out and wound it to the max revs which i was happy to sit at on a motorway/duel carrageway so went up the road and back.
Must admit i do have a soft spot for small frames :shock: good speeds though fella , now get it put away and get the grass cut before the Mrs gets back :lol: :lol: :lol:
soosh
Only cut the grass last Fri but lots of rain and then this sun,guess it goes mental.
Dryballs
Whats the engine?
I tuned Mrs Balls smallframe in secret for her, but then she got pregnant so has only ridden it twice!
I lent it to a mate to ride the other week and he was quite surprised how fast it was - it beat quite a few of my other mates
That is just a polini 130 with 18mm carb and standard exhaust. I did get some fat fingers up the barrel first though
soosh
Not fat fingers in the exhaust port though? It a slightly ported Parmakit with 28phbh,hammerzombie mk1 and std electronic ign. The Polini is a good kit,a mate uses one and its very reliable and it flies. You done the inlet timing on the crank? Change carb to a 25.
