FOXHAT clutch spider
fishi
Hi mates,
want to order a FOXHAT cluch spider to use with 6-7 plates.
Anybody has one in use and can tell how much power must be used to pull the clutch lever ?
Is it comparable with standard or much more heavy to actuate? With which spirngs should be used ?
Thankx
fishi
The spider has nothing to do with how heavy the clutch action is.....that's down to your choice if springs. I use MB springs on my Foxhat 6 plater.
fishi
drunkmunkey6969 wrote:The spider has nothing to do with how heavy the clutch action is.....that's down to your choice if springs. I use MB springs on my Foxhat 6 plater.
OK, and how does it feel ? Is the clutch heavy to actuate ?
Do you use the MB springs for 4-5 plates?
    Users browsing this forum: Baidu [Spider], Semrush [Bot] and 16 guests
