PX Flywheel side oil seal
Posted: Mon Jul 09, 2012 9:21 am
by dopeshots
Quick one, can the flywheel side oil seal be done in situ or do u have to split the cases. Its a P2 motor.
Cheers]
:fb:
Re: PX Flywheel side oil seal
Posted: Mon Jul 09, 2012 9:38 am
by gaz_powell
yes
no problem at all - use a small pick to remove the existing - lightly grease up the new seal and pop it on carefully and square - it should go on with finger pressure only - if it is tight make a soft drift
best of luck
Posted: Mon Jul 09, 2012 9:44 am
by dopeshots
thank you
