PX Flywheel side oil seal
dopeshots
Xbox live gamer tag: rms789
Main scooter: GP150
Quick one, can the flywheel side oil seal be done in situ or do u have to split the cases. Its a P2 motor.
Cheers]
:fb:
gaz_powell
yes
no problem at all - use a small pick to remove the existing - lightly grease up the new seal and pop it on carefully and square - it should go on with finger pressure only - if it is tight make a soft drift
best of luck
dopeshots
Main scooter: GP150
thank you ;)
