chiselspeed m tech unit
heliscoot
Playstation gamer tag: heliscoot
Scooters become a bugger to start and sometimes tries to kick back when kick starting I reckon timing issue. As I have just had the engine out I may have got the m tech unit wiring wrong. Can someone tell mw the correct connections as I m on a rally at mo cheers
its fairly simple.....the red wire from your stator/cdi should be unplugged from the cdi and inserted into the red wire/male connector from the mtech....and the other red wire/female connector from the mtech goes into the red slot on the cdi. The black wires from the mtech are simply earths.
heliscoot
Cheers for that.
heliscoot
heliscoot wrote:Cheers for that.
Well just checked and that seems fine. Owt else that may give these symptoms. Once started seems ok and rode to cleggy fine at all speeds
mcbrid
I have one of these fitted to my TS1 and it does seem reluctant to kick off sometimes but then works a treat!
Dont suppose you could have adjusted the setting?
Not M tech expert though
heliscoot
No not touched it , Martin fitted it and dynoed it last year always started first kick. I.ll check it over tomorrow,strobe it up see what it's running at and do the other obvious stuff.
heliscoot
Well sods law it started first kick every time today so whether it was a poor connection somewhere or it just wanted to embarrass me outside a packed boozer. Anyway I ll call it a win. Cheers for the comments
    Users browsing this forum: Ahrefs [Bot] and 11 guests
