Page 1 of 2
Dellorto needle advice
Posted: Thu Jun 21, 2012 10:24 pm
by djh66
Is a X13 needle richer than a X7? Cheers Dave
Re: Dellorto needle advice
Posted: Fri Jun 22, 2012 9:44 am
by djh66
Anyone?
Posted: Fri Jun 22, 2012 9:46 am
by col68
yes mate :fb:
Posted: Fri Jun 22, 2012 11:24 pm
by wack 63
Only richer as it gets on to the taper earlier,the 1/4 throttle position is still the same (2.5mm) http://www.dellorto.co.uk/images/parts/ ... charts.pdf
Posted: Sat Jun 23, 2012 8:44 am
by DaveTomo
Leanest - X12 - X7 - X13 - X2 - X25 - X10 - X16 - X32 - Richest
Posted: Sat Jun 23, 2012 9:31 am
by Daggs
DaveTomo wrote:Leanest - X12 - X7 - X13 - X2 - X25 - X10 - X16 - X32 - Richest
Hmmmm ! That's a nice logical sequence. Thanks Dellorto............................................... ;)
Posted: Sat Jun 23, 2012 9:52 am
by Special X
wack 63 wrote:Only richer as it gets on to the taper earlier,the 1/4 throttle position is still the same (2.5mm) http://www.dellorto.co.uk/images/parts/ ... charts.pdf
My scoot when fitted with an X7 is rich at 1/4 throttle and pinks at 1/3 - 1/2 throttle. An X13 cures the pinking but is still rich at 1/4 throttle. I'm on an AV266 I'm going to try using an AV264 and moving the X13 1 clip richer to see if I can get it right.
So yes an X7 is weaker at least to 1/2 throttle but stays rich at the bottom end.
Posted: Sat Jun 23, 2012 3:02 pm
by jonny snatchsniffer
fit a weaker slide if yr rich up to 1/4
Posted: Sat Jun 23, 2012 3:36 pm
by Special X
Already on a 45 - anyone reckon I dare fit a 50? It's ok on tickover, ok on progression (up to just over 1/8 throttle) massively rich at just under 1/4 throttle to just under 1/3 throttle then OK all the way up (needle at 1st clip)
With an X7 it's the same but pinking in the mid throttle positions. Choke is deffo not leaking.
Posted: Sat Jun 23, 2012 3:42 pm
yeah id fit a 50, or if you have a spare slide file it till u get the desired effect
