Dellorto needle advice
djh66
Main scooter: 150 special
Is a X13 needle richer than a X7? Cheers Dave
Bring Me Sunshine COYH
djh66
Anyone?
col68
Main scooter: lambretta s2 li225 ts1
yes mate :fb:
wack 63
Main scooter: '71 GP TS1
Only richer as it gets on to the taper earlier,the 1/4 throttle position is still the same (2.5mm) http://www.dellorto.co.uk/images/parts/ ... charts.pdf
DaveTomo
Main scooter: SX 200
Leanest - X12 - X7 - X13 - X2 - X25 - X10 - X16 - X32 - Richest
Daggs
DaveTomo wrote:Leanest - X12 - X7 - X13 - X2 - X25 - X10 - X16 - X32 - Richest
Hmmmm ! That's a nice logical sequence. Thanks Dellorto............................................... ;)
Special X
wack 63 wrote:Only richer as it gets on to the taper earlier,the 1/4 throttle position is still the same (2.5mm) http://www.dellorto.co.uk/images/parts/ ... charts.pdf
My scoot when fitted with an X7 is rich at 1/4 throttle and pinks at 1/3 - 1/2 throttle. An X13 cures the pinking but is still rich at 1/4 throttle. I'm on an AV266 I'm going to try using an AV264 and moving the X13 1 clip richer to see if I can get it right.
So yes an X7 is weaker at least to 1/2 throttle but stays rich at the bottom end.
jonny snatchsniffer
fit a weaker slide if yr rich up to 1/4
Special X
Already on a 45 - anyone reckon I dare fit a 50? It's ok on tickover, ok on progression (up to just over 1/8 throttle) massively rich at just under 1/4 throttle to just under 1/3 throttle then OK all the way up (needle at 1st clip)
With an X7 it's the same but pinking in the mid throttle positions. Choke is deffo not leaking.
jonny snatchsniffer
yeah id fit a 50, or if you have a spare slide file it till u get the desired effect
