new piston and rings
dapper
- Main scooter: The Biriani Bullet
You don't say what type of cylinder it is. If it's nicasil lined, then about 250 to 500 miles. If it's cast or steel lined, then around 1000 miles.
did you check piston,bore clearance? if above 3.5 thou,then a few hundred miles should do.
soosh
- Main scooter: GP RS200 Iron barrel
That's a good opinion too as my new piston went in and then used as normal,no worries.mick1 wrote:IMO.....if your barrel hasn't altered and it's just new rings/piston then 50 mile should be ok....but that's my opinion..
- Muttley McLadd
1000 miles?
There's some barrels would be half worn out by the time they've been run in!
bristolmod
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
has it been rebored to suit?
If not then I'd go with 50/100 miles as long as you've "glaze busted" the bore
Scootering since 1968.
