new piston and rings
Tosh
how long to run in new rings & piston,not had a re bore it lost pin in piston and broke rings,std 66mm bore
dapper
You don't say what type of cylinder it is. If it's nicasil lined, then about 250 to 500 miles. If it's cast or steel lined, then around 1000 miles.
fred
did you check piston,bore clearance? if above 3.5 thou,then a few hundred miles should do.
mick1
Main scooter: Li Avanti 225
IMO.....if your barrel hasn't altered and it's just new rings/piston then 50 mile should be ok....but that's my opinion..
soosh
mick1 wrote:IMO.....if your barrel hasn't altered and it's just new rings/piston then 50 mile should be ok....but that's my opinion..
That's a good opinion too as my new piston went in and then used as normal,no worries.
1000 miles?
There's some barrels would be half worn out by the time they've been run in!
bristolmod
has it been rebored to suit?
If not then I'd go with 50/100 miles as long as you've "glaze busted" the bore
Scootering since 1968.
Tosh
thanks everybody for the reply`s,its a cast barrel,no need to re-bore only a very very small chip on exhaust port but that`s sorted,1700 miles,3thou clearance on piston and ring gap 10thou
    Users browsing this forum: Ahrefs [Bot] and 9 guests
