SIP tubeless - valve adaptor?
Mongo
Main scooter: Vespa Rally 200
Do you need a valve adaptor to get air in through the valves with the SIP tubeless rims? Tried using the airline at two local garages to check pressures/ top up the air, and all it does is let air out. :wtf:
