Mugello 200 28phbh jetting help.
scoot gp
Bought a 28phbh to replace my 25phbh, will be runing a standard mugello 200, clubman pipe and a 28phbh with a ram air filter.
Does anyone have the same setup and could point me in the right direction for jetting please?
jonnyb
Main scooter: Li150 Special
You could try the jetting that I use on my 30mm Mugello V4 200 as a starting point, it should be a tad rich which wouldnt be a bad thing?
AV264 X13 second from top clip 45 slide 120 main 53 pilot.
I'm sure someone who has the same setup as you will be along soon :)
scoot gp
Thanks, it's only so I can get it running somewere neat before getting dyno'd
Special X
jonnyb wrote:You could try the jetting that I use on my 30mm Mugello V4 200 as a starting point, it should be a tad rich which wouldnt be a bad thing?
Take the main to 115 and you'l be in the ballpark for a PHBH 28.
mickdale
hello jonnyb
can you tell me what filter you use if at all?
cheers
mick
    Users browsing this forum: Ahrefs [Bot] and 3 guests
