30mm phbh dellorto/jimmers manifold
db67
hi, currently running a 30mm phbh on my gp ts1 with an mb short inlet manifold & remote air filter.problem is when i try to fit the side panel it squashes the filter bellows & obviously makes the scoot run rough & bog down !! just wanted to know if i fit one of the jimmers manifolds will it give me more room than the mb inlet ? dont really want to go down the hole in the panel route. thanks for any info. db67 :)
Dryballs
Yeah it will give you quite a but more room
Not sure if it will be enough with a phbh tho? I don't have much experience with those carbs
I am here: http://tapatalk.com/map.php?oambpe
    Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 4 guests
