Rear wheel rubbing
Joe shields
Main scooter: Lambretta gp 186 mugello
My series 3 li has an rb 20 in, i have just taken it out and serviced it but when it all went back in the scoot the rear wheel was rubbing against the panel rollers, I have checked the engine mounts they are fine the cones are all ok I have replaced the rear tyre and it is an s1, checked the rear hub no play in it and the shock is fine.
was wondering if any one has any ideas about it I have tried to figure it out but it makes no sense, help :cry:
blue
Have you checked your frame behind your engine mounts, they have been known to snap here.
Timbo
Does the rear wheel line up correctly with the frame?
Torco225
Main scooter: Lambretta TS1 225
Joe send us a pic ..... think I've seen similar before .
Rich
Joe shields
i havnt checked the frame i have now loctited the cones in position and changed the 100/90 tyre and its stopped rubbing just a bit close and the wheel is a little off cock to the frame but not much
