*****SIP FLOW TAP TEST*****
H,POOL GADGE
100% gaurentee this test, done by me! this is not s**t bullshit.....
okay i done a test to illiminate flat spots and scoot cutting out on full throttle...anyway the results are!
SIP FAST FLOW TAP/TANK IN SCOOT AND TAP ON RESERVE = 1 minute - 500ml / 7/8 of a pint
STANDARD TAP/TANK IN SCOOT AND TAP ON RESERVE = 1 minute - 300ml / a touch over 1/2 a pint
SO THERE YOU HAVE IT A SIP FAST FLOW TAP IS WELL WORTH THE MONEY AND NOT S**TE......... :bouncyeng:
philhnottm
Main scooter: px (s)
so what causes the cutting out when you let off the throttle???
H,POOL GADGE
f*^ked if i know! just started doing it...were'z the scooter engine Guru's, come on think, Help!!!!!!!!!!!!!!!!!!!!!!!!!!
