Page 1 of 2
SIP fast flow tap!!!
Posted: Wed Jun 06, 2012 6:13 pm
by H,POOL GADGE
Anybody having problems with these? when pushing scoot through the gears, am getting a flat spot between 2nd / 3rd and more so 3rd / 4th, and when flat out and shut throttle off scooter cuts out! what the f*^ks that all about!!!
av blown carb out and petrol pipe out and alls clean! anymore ideas lads? head buster!!!!
Re: SIP fast flow tap!!!
Posted: Wed Jun 06, 2012 9:14 pm
by goldeneye
ive had problems with 2 different kinds of FF tap for vespas, one a beedspeed one (blue anodised) wouldnt turn off. the other a SIP, again, would still flow fuel , albeit a slight amout , when shut off. try the float needle for wear, the extra flow of fuel may be overpowering a worn rubber tipped needle, and causing flooding symptoms.
Posted: Wed Jun 06, 2012 9:45 pm
by H,POOL GADGE
cheers goldeneye, can't see it being needle but will check, gunna do a flow test t,mora! It,s 1/2 a pint a minute innit...
Posted: Wed Jun 06, 2012 9:51 pm
by H,POOL GADGE
and ye right about the flow of fuel when the sip taps turned off!!!!! am sick as f*^k with tackle fanny shite people invent and sell, ye phone beedspeed and they think ye f*^king stupid.....BAH!!!!!!!!!!!!!!!!
Posted: Wed Jun 06, 2012 9:54 pm
by philhnottm
H,POOL GADGE wrote:Anybody having problems with these? when pushing scoot through the gears, am getting a flat spot between 2nd / 3rd and more so 3rd / 4th, and when flat out and shut throttle off scooter cuts out! what the f*^ks that all about!!!
I had this when running in a 166 did 1000 miles . No one knew why it kept dying as again it was when shutting off throttle . Would happen at 15mph as well as 50 MPH
We fitted a sip FF tap and it cured it for a short time before before the main engine seal went and engine went .
Interesting thread as could this be anything else other than the tap??
Posted: Wed Jun 06, 2012 11:47 pm
by joeythescooterboy
Even if the tap isn't shutting off 100% the float needle shouldn't be letting any more in once the bowl is full............. I'd be checking the float and needle before knocking the tap.
Posted: Thu Jun 07, 2012 10:32 am
by gaz_powell
ive fitted one but havent really used the bike yet ...... did notice it doesnt close completely ........never had a problem with the genuine piaggio one just thought the up grade would be for the better........... back to standard tap asap as i cant be arsed on with crap relating to a tap
Posted: Thu Jun 07, 2012 2:40 pm
by hungdog
Have you tried the spring loaded float needle http://www.sip-scootershop.com/en/produ ... +_40090600
Posted: Thu Jun 07, 2012 3:08 pm
by H,POOL GADGE
gunna order the 5.2 needle as i have the cosa cap on my 24/24, i,ve checked the existing 5.2 needle and float with a magnifying glass and can't see now,t untoward, but onwards and backwards.....
Posted: Thu Jun 07, 2012 5:18 pm
by Doom Patrol
Have you looked inside the fuel tank?
