vespa t5 cosa clutch
Posted: Mon Jun 04, 2012 9:30 pm
by dilan
hi i have been looking at putting a cosa clutch on my t5 but when i read the description about the clutch it says i need to modify the clutch casing to stop the clutch fouling on it , does anyone know what this modification is? cheers
Re: vespa t5 cosa clutch
Posted: Mon Jun 04, 2012 10:11 pm
by wack 63
When the cover is off you will see a couple of ribs about 12 o/clock,these need grinding down.
Posted: Mon Jun 04, 2012 10:16 pm
by dilan
cheers mate been wondering what it was for a while.
Posted: Mon Jun 04, 2012 10:17 pm
by H,POOL GADGE
gadge, to elliminate any problems people say they've had is to file the turrets to 22mm deep, where the tangs of the clutch plates slide
Posted: Tue Jun 05, 2012 12:17 am
by paul d
I doubt you'll have to modify the clutch cover on a T5 engine to fit a cosa clutch . I'm almost certain that the T5 clutch cover is the same as a 200 one .
Posted: Tue Jun 05, 2012 9:23 am
by goldeneye
paul d wrote:I doubt you'll have to modify the clutch cover on a T5 engine to fit a cosa clutch . I'm almost certain that the T5 clutch cover is the same as a 200 one .
the cover will have "200" stamped inside . its only early p/px 125"s that have the ribs inside.
