vespa t5 cosa clutch
dilan
Xbox live gamer tag: buddah dil
Playstation gamer tag: Buddah_Dil
Main scooter: vespa px 125
hi i have been looking at putting a cosa clutch on my t5 but when i read the description about the clutch it says i need to modify the clutch casing to stop the clutch fouling on it , does anyone know what this modification is? cheers
Dilan vesperados
wack 63
Main scooter: '71 GP TS1
When the cover is off you will see a couple of ribs about 12 o/clock,these need grinding down.
dilan
cheers mate been wondering what it was for a while.
Dilan vesperados
H,POOL GADGE
gadge, to elliminate any problems people say they've had is to file the turrets to 22mm deep, where the tangs of the clutch plates slide
paul d
Main scooter: T5 172 Tv 240
I doubt you'll have to modify the clutch cover on a T5 engine to fit a cosa clutch . I'm almost certain that the T5 clutch cover is the same as a 200 one .
goldeneye
paul d wrote:I doubt you'll have to modify the clutch cover on a T5 engine to fit a cosa clutch . I'm almost certain that the T5 clutch cover is the same as a 200 one .
the cover will have "200" stamped inside . its only early p/px 125"s that have the ribs inside.
