rapido jetting advice needed
Posted: Thu May 31, 2012 11:02 pm
by rapido230
hi, yes another jetting enquiry
set up:
rapido race 225
race tour piston
stage 5 fast touring tune with boost port and mbd 6 petal reed block
bgm 60mm crank with 3mm packer
dellorto 30mm open mouth
55pilot
266 av atomiser
140 main
40 slide
taffy pipe.......am i heading in right direction with jetting?
Re: rapido jetting advice needed
Posted: Thu Jun 07, 2012 6:35 pm
by col68
you cant be far off , it the same jetting as my ts1 225 jetting . do some plug chops the will tell you . :bouncyeng:
Posted: Fri Jun 08, 2012 1:15 pm
by rapido230
thanks, spat a bit of fuel out and was way too rich, plug way black, gone down to a 264 av atomiser and even then gone down to leanest setting, seams quite crisp, ill do more plug chops
Posted: Fri Jun 08, 2012 3:23 pm
by Eibar
u ain't said what needle your running,
my settings are
225 rapido (harry barlow transfers flowed better)
x7 p2.5
av266
55 pilot
118 main running open
18 degrees
PHBH and Nk Rally
Air fuel ratio is spot on
Posted: Fri Jun 08, 2012 4:17 pm
by rapido230
flicking between x2 and x13 at moment , 2nd from top on x13 feels great and good plug colour, bearing in mind i still got bit running in to do lol
