hi, yes another jetting enquiry
set up:
rapido race 225
race tour piston
stage 5 fast touring tune with boost port and mbd 6 petal reed block
bgm 60mm crank with 3mm packer
dellorto 30mm open mouth
55pilot
266 av atomiser
140 main
40 slide
taffy pipe.......am i heading in right direction with jetting?
rapido jetting advice needed
- rapido230
- registered user
- Main scooter: vespa 210 & lambretta gp
- Contact:
thanks, spat a bit of fuel out and was way too rich, plug way black, gone down to a 264 av atomiser and even then gone down to leanest setting, seams quite crisp, ill do more plug chops
Eibar
- registered user
- Main scooter: Eibar TS1 1966
- Contact:
u ain't said what needle your running,
my settings are
225 rapido (harry barlow transfers flowed better)
x7 p2.5
av266
55 pilot
118 main running open
18 degrees
PHBH and Nk Rally
Air fuel ratio is spot on
my settings are
x7 p2.5
av266
55 pilot
18 degrees
PHBH and Nk Rally
potato
