Aerox Fork Stem/Triple Tree Measurements
everyman07
noob
Main scooter: 07 Vespa GTS250
Hi
I'm mating an aftermarket front suspension designed for the Yamaha Aerox (which we don't get here in the US) to another scooter.
I'm missing the triple tree and need to fabricate one to make this work. What would really help is a couple of the dimensions of the Aerox triple tree (fork stem) since I can't get my hands on one to measure it. Part #4TD-F3340-01
I'm looking for the distance (center to center) between the fork leg brackets and the distance (center to center) between the fork leg bracket and the stem.
Really appreciate any help you can be.
Andrew
