The cylinder was coupled with an asso 1.5mm ring piston so the port widths were kept mild so nothing extreme in its layout which comprised single exhaust port 2 transfers and a single boost port was added
the porting layout is very simple in appearance but accurate in respect to port durations ,areas and angles its exhaust port/inlet port and base gaskets are all to standard gasket sizes.
