Ignition help
carpetmonkey
Scooter runs fine and everything works, if green ignition is pulled out of CID, soon as you reconnect it cuts out...... Scratching my head help needed
lambro
carpetmonkey wrote:Scooter runs fine and everything works, if green ignition is pulled out of CID, soon as you reconnect it cuts out...... Scratching my head help needed
So, if you disconnect the green loom wire that feeds the ignition cutout.
The scoots and runs fine, just wont switch off on key.
That would say the pink/green wire in the headset connection is dodgy/loose, or you have a shitty Indian ignition switch.
Stick a Casa one in, and all will be good.
Shaun.
