Gudgeon pin wear ?
bizzly
A friend of mine decided to strip his top end down after hearing an unusual clattering in the barrel area. There was quite a bit of play on the piston / gudgeon pin area, so thought his little end bearings had gone kaput......After some grunting and hammering, we managed to get the pin out and noticed the wear on it. I have never seen wear like this, so thought I would ask on here as to why it would happen.
Cheers
Bizz
joespeed
i think i have the answer;- it was made in scunny using scunny steel!
sorry couldn't resist that! come over to selby this saturday i'll give you a new one,
regards
joe
bizzly
joespeed wrote:i think i have the answer;- it was made in scunny using scunny steel!
regards
joe
LMAO :lol: :lol: Its been in 4 year without a checkup :roll: :lol:
camel
was there lubrication holes in the piston?
bizzly
camel wrote:was there lubrication holes in the piston?
No....rapido I think :? Asso piston, 2 holes in rod to small end bearing.
nelson pk
Is it run on decent oil and at what ratio?
nelson pk
Also, what sort of quality was the small end? Was a 20mm small end fitted when it needed a 22m? (length of small end between piston not diameter).
bizzly
nelson pk wrote:Also, what sort of quality was the small end? Was a 20mm small end fitted when it needed a 22m? (length of small end between piston not diameter).
He's not sure what make the small end bearing is, as he put it in about 4 year ago, but the roller bearing was the same width as the small end on crank. He also uses Rock oil fully synthetic at 4%.
nelson pk
If the piston has got a 22mm gap or very slightly over between where the small end fits, a lot of tuners advise the use of a 22mm long small end regardless of weather this pokes out a bit either end on the eye of the rod because if you use a shorter small end, the small end can move along the gudgeon pin and then only a proportion of the conrod eye is making contact with the small end if you see what i mean, and therefore you are getting uneven pressure on approx half of the bearing.
I would measure the gap where the conrod sits on the piston and if its 22mm or very slightly over get a 22mm long bearing. MBD used to do them and camb lam do them as well. I think they come out of a Yamaha but i dont know which one.
bizzly
Thanks nelson :D much appreciated
    Users browsing this forum: Ahrefs [Bot] and 17 guests
