Bizz
LMAOjoespeed wrote:i think i have the answer;- it was made in scunny using scunny steel!
sorry couldn't resist that! come over to selby this saturday i'll give you a new one,
regards
joe
He's not sure what make the small end bearing is, as he put it in about 4 year ago, but the roller bearing was the same width as the small end on crank. He also uses Rock oil fully synthetic at 4%.nelson pk wrote:Also, what sort of quality was the small end? Was a 20mm small end fitted when it needed a 22m? (length of small end between piston not diameter).
