Quick PK50 question
storkfoot
I'm not up to speed on smallies but would I be right in thinking that a PK50 engine will drop into a pre-PK model frame, say a 50N or 50 Special?
Thanks in advance
soosh
Yes it will.
storkfoot
Thanks
madmax
The PK inlet manifold has a different angle than the V range and you'll have to widen the hole in the frame for it to go through.
Is the inlet 2 or 3 studs? If its 2 studs, you can fit a V range manifold and you won't need to modify/widen the hole. ;)
storkfoot
I missed out on the engine anyway but cheers for that. I'll bear it in mind if another comes up ;)
