GT186 ADS3 30mm PWK Jetting Suggestions?
RobD
Looking for advice on a starting point for a GT186 with ADS3 pipe and a 30mm PWK please?
Have done a search but could only find people using the 24mm.
Yanker
Not quite there yet Rob, due to a premature crank failure (don't ask)
Built a similar motor (GT186 + B-race snail) and put a 138 or 140 main in, jjh clip 3 and i think 38 idle. It ran on the stand without 4 stroking badly.
Stopped because of above, now going back together with a DT175 piston (66mm) and should be running again soon. Some body build to finish as well. Will happily 'swap notes' with you when on the road :-)
    Users browsing this forum: No registered users and 30 guests
