best pipe?
Posted: Mon May 07, 2012 7:40 pm
by dilan
Can anyone tell me what they think of the sterling pipes for vespa t5 standard or should i invest in a pm tuning pipe ? or even a different pipe which is best. cheers
Re: best pipe?
Posted: Mon May 07, 2012 7:57 pm
by goldeneye
if it"s a standard T5...the standard T5 pipe, or a sito plus box works best.
Re: best pipe?
Posted: Mon May 07, 2012 8:17 pm
by roadrunnerian
it depends do you want to take the exhaust off every you have a busted tyre use a jl rh in mild steel if not or if you don't mind get a taffspeed orginal lh or there is a german make which is suppose to be the dogs. dont use stainless mild steel only.
Re: best pipe?
Posted: Tue May 08, 2012 1:07 am
by paul d
I'm in full agreement with goldeneye . I've tried a scorpion on a standard T5 . It gave the scooter more power but the powerband was so narrow that the bike was slower over distance than one with a standard exhaust ! The sito plus is better than standard but the noise it makes takes alot of getting used to . Even on a kitted T5 the sito has alot going for it . Dont forget to upjet slightly if you bolt on any other exhaust besides standard .
