best pipe?
dilan
Xbox live gamer tag: buddah dil
Playstation gamer tag: Buddah_Dil
Main scooter: vespa px 125
Can anyone tell me what they think of the sterling pipes for vespa t5 standard or should i invest in a pm tuning pipe ? or even a different pipe which is best. cheers :)
Dilan vesperados
goldeneye
if it"s a standard T5...the standard T5 pipe, or a sito plus box works best.
roadrunnerian
it depends do you want to take the exhaust off every you have a busted tyre use a jl rh in mild steel if not or if you don't mind get a taffspeed orginal lh or there is a german make which is suppose to be the dogs. dont use stainless mild steel only.
paul d
Main scooter: T5 172 Tv 240
I'm in full agreement with goldeneye . I've tried a scorpion on a standard T5 . It gave the scooter more power but the powerband was so narrow that the bike was slower over distance than one with a standard exhaust ! The sito plus is better than standard but the noise it makes takes alot of getting used to . Even on a kitted T5 the sito has alot going for it . Dont forget to upjet slightly if you bolt on any other exhaust besides standard .
