Warning: Non Nissin ScootRS disc brake caliper
Bufficus
My mate just had a brake caliper fail on his early ScootRS front disc brake.
This is the NON Nissin pattern type, which were used on early models.
If you have one of these pattern calipers fitted you may want to consider upgrading it.
noggin1969
not the 1st time either
Has a mind full of useless s**t and isn't afraid to use it !
ArKaTxU
wow!
teamv
its not just that ,the disc's split as well
scootRS.com
There are various quality discs (the disc itself) available so we always get the best we can but I've never heard of even one of ours splitting. Hard to imagine what would even split. I wouldn't even worry about that happening.
For calipers, we haven't used the non-Nissin ones since we secured a supply from Nissin maybe 4 years ago now, I forget. For a whole year afterward we offered a very cheap upgrade to all past customers.
A lot of the sandcast kits being sold in the UK come with those calipers though, and the cheapest discs. (The big problem with the cheaper discs is trueness.) Then again, so do millions of Chinese scooters.
