10% Discount on Dyno Tuning for Scooterotica forum members!
Last night after a conversation with other forum Administrators it was agreed that it would be nice to give something back to the forum members for their continued and loyal support of Scooterotica. Other dealers do offer up promotional discounts such as Diablo on his tanks and Exol on their oil, along with others, and so we intend to come up with our own various offers and promotions as and when possible.
To start the ball rolling i'm going to offer a 10% discount off my dyno service for all forum members who wish to take advantage. The way this works is that i will publish a monthly promotion code during the periods that the promotion is running, and all you have to do is contact me via PM quoting the code and when i make the booking i will deduct 10% from your final total bill.
The promotional code for May 2012 is: DYNO-04-12 (took me ages to think that up! :roll: :D ) to make a booking simply send me a PM and quote this code.
Most of you will be familiar with the dyno service we run, but for those that are not, see here:
Scooterotica Dyno Tuning & Diagnostics
Why choose Scooterotica Dyno Tuning & Diagnostics?
Given that Lambretta and Vespa scooters are based on a 40+ year old design.....trying to get them to go fast, or expecting them to cover thousands of miles to and from rallies can be a difficult experience. Even the most seasoned professional can't accurately examine the entire rev range under load and get the jetting 100% spot on.....and this is where dyno tuning comes in!
Our dyno is perfectly engineered to analyize the performance, BHP, torque and revs of your scooter. Combine this with the gas analyser unit and we can examine how your engine is performing and make sure you have the correct air/fuel ratio so to prevent either lean running and seizures, or rich running and lost performance.
Process:
When we book a customer in for a dyno tuning & diagnostic session, i try to have a chat with the customer on the phone first about what they are expecting, known problems with the scooter, what we can/cant do for them etc, so that there is at least a basic understanding of what will happen on the day.
Upon arrival, we have a brew and chat in a bit more detail, we also have a job sheet that we request the scooter owner fills in, answering pre-filled fields: Engine spec, exhaust type, ign timing, carb spec, jetting settings, gearbox type, known issue and problems that need resolving etc, so that we have as much info as possible to start with.
After this we will get the scoot warmed up set it up on the dyno with the gas analyser plugged in etc and do 1 batch of runs, 1 batch actually consists of 3 runs. We usually do 1 run through gears 1st-3rd just to clear the engine, then do run 2 getting the throttle wide open as soon as i can in the rev range, and then run 3 feeding the throttle to roll on the power. We can also repeat the batch runs holding in 4th gear once the engine is warm to gain as much info as possible.
So we should now have at least 3 graphs to choose from and analyse, if there were any glitches, or misreadings we would repeat until we get some meaningful data that we can interpret and relay to the customer.
At this point, if any adjustments are needed, the customer can either request that we do the work there and then, fit parts, tune and re-test on the dyno afterwards to check progress...... or they can take the info/graphs/BHP/Torque/Air/Fuel-analysis away and make their own adjustments accordingly....its the customers choice, so that they don't feel that their wallet is an open book.....their spend with us will be tailored to their needs and requirements.
Important Note:
During a standard Dyno Tuning & Diagnostic session, we will measure BHP/TORQUE/RPM figures along with important Air/Fuel ratio information, and use this information to fine tune your scooter and set up your carb properly. However, due to time constraints, major mechanical faults and defects cannot be fixed during a dyno tuning and diagnostic session. Such items should be booked into the garage for mechanical work seperately. Only when the scooter is mechanically sound, can the dyno be used to fine tune the carb and performance.
Prices:
Batch of 3 Dyno Power runs with Air/Fuel Diagnostics - BHP/TORQUE/RPM figures with fuel/air ratio mix analysis £35.
After the first batch of power runs, each additional batch is charged at £10 per batch on the same day.
Workshop time labour charge if tuning work required - £30 ph.
Parts (Jets, slides, atomisers etc) charged on top.
Examples:
Example 1 - Dyno power run (batch of 3) with Air/Fuel Diagnostics, customer take printout information away: £35
Example 2 - Dyno power run (batch of 3) with Air/Fuel Diagnostics, customer makes own adjustments and provides own parts, we then do an additional block of runs to re-test: £45
Example 3 - Dyno power run (batch of 3) with Air/Fuel Diagnostics, we spend 1 hour tuning your scooter and do an additional run to re-test: £75 (plus parts)
We carry a full range of spares for Mikuni and Dellorto carbs, so if needed, we can adjust your carb on site. Cost of parts is additional, as supplied.
Our workshops are based in Ripon, North Yorkshire, so to make a booking with Scooterotica, or to discuss options....feel free to either phone Dan on: 07534 375 813 or email: [email protected]
