Page 1 of 2
M Tech or Augusta.................. Discuss
Posted: Wed Apr 25, 2012 6:39 pm
by dapper
What are the pros/cons twixt the two?
Posted: Wed Apr 25, 2012 7:49 pm
by soulsurfer
Or throw the Readspeed CDI into the mix and discuss thrice :D
Re: M Tech or Augusta.................. Discuss
Posted: Wed Apr 25, 2012 8:29 pm
by GP Kevo
Yes, please, I'm all ears. Really, though, I think I would go for the simplest to fit and set up solution, that being Agusto as far as I know.
Posted: Thu Apr 26, 2012 5:46 pm
by Timbo
dapper wrote:What are the pros/cons twixt the two?
Ones a very hard to play golf course.... :lol: .....sorry Mark, couldn't resist. The one that begins with A works for me, but isn't it better to get it set up on a dyno?
Posted: Thu Apr 26, 2012 6:14 pm
by JINX
Here's one difference between them:
Agusto has a fixed degree shift, matched to the rpm. Hence them being named 6000/8000.
The M tech has 16 points of adjustability per revs, and also the amount of degree shift.
I have one fitted up, but not yet kicked over. I will say it came with nice instructions and a clear graph that showed off the degree shift per rev, across the 16 position range, in other words, smart and simple.
Posted: Thu Apr 26, 2012 6:29 pm
by roadrunnerian
Hi i have an augusta fitted to my ts1 the scooter pulls well from low revs that i found is the biggest plus since i fitted my 7000 well chuffed :lol:
Posted: Thu Apr 26, 2012 8:25 pm
by soosh
The readspeed one has a retard setting too so can help in an emergency situation like s**t fuel or air leak.
Posted: Sat Apr 28, 2012 1:44 pm
by dapper
But do they cause possible damage to the engine if they suddenly pack up?
Posted: Sat Apr 28, 2012 1:58 pm
by cezeta
dapper wrote:But do they cause possible damage to the engine if they suddenly pack up?
possibly as you will fail in an advanced setting of 20-25 degrees depending on set up
Posted: Fri May 04, 2012 3:38 am
by Minority
Looks like the Readspeed CDI takes care of this (looking at their graphs) by setting the static timing as normal and having the timing advance from 0-3500rpm and then retard back to the static timing setting as revs rise.
