M Tech or Augusta.................. Discuss
dapper
What are the pros/cons twixt the two?
Or throw the Readspeed CDI into the mix and discuss thrice :D
GP Kevo
Yes, please, I'm all ears. Really, though, I think I would go for the simplest to fit and set up solution, that being Agusto as far as I know.
Timbo
dapper wrote:What are the pros/cons twixt the two?
Ones a very hard to play golf course.... :lol: .....sorry Mark, couldn't resist. The one that begins with A works for me, but isn't it better to get it set up on a dyno?
JINX
Here's one difference between them:
Agusto has a fixed degree shift, matched to the rpm. Hence them being named 6000/8000.
The M tech has 16 points of adjustability per revs, and also the amount of degree shift.
I have one fitted up, but not yet kicked over. I will say it came with nice instructions and a clear graph that showed off the degree shift per rev, across the 16 position range, in other words, smart and simple.
roadrunnerian
Hi i have an augusta fitted to my ts1 the scooter pulls well from low revs that i found is the biggest plus since i fitted my 7000 well chuffed :lol:
soosh
The readspeed one has a retard setting too so can help in an emergency situation like s**t fuel or air leak.
dapper
But do they cause possible damage to the engine if they suddenly pack up?
cezeta
dapper wrote:But do they cause possible damage to the engine if they suddenly pack up?
possibly as you will fail in an advanced setting of 20-25 degrees depending on set up
Minority
Main scooter: Li230 S3
Looks like the Readspeed CDI takes care of this (looking at their graphs) by setting the static timing as normal and having the timing advance from 0-3500rpm and then retard back to the static timing setting as revs rise.
