Italian series 2 legshields
andy summers
Hi
Having problems working out how I fit the mudguard lower fixings onto series 2 legshields. They have the 2 locating lugs/mounting points but are they supposed to be threaded? If so mine seem to be stripped or do I some how need to slip a nut inside the lug to thread he bolt through?? :?
Thanks in advance.
WINTERMODEL150
andy summers wrote:Hi
Thanks in advance.
Hi,yes they are threaded M5 type washers behind the bracket but if these are stripped then you can tap them out to M6 or slip a nut behind it ...what ever takes ya fancy really :D
Dean
andy summers
Thanks in advance.
Dean
cheers Dean, will tap them to m6.
