engine mount bolt stuck?
Posted: Wed Apr 11, 2012 9:57 am
by servetakid
Ok, my engine mount bolt is stuck. It gets stuck as you try to knock it out of the second mount. The bolt is a tight fit between the mounts, any suggestions on how to ease the bolt out would be welcome.
Re: engine mount bolt stuck?
Posted: Thu Apr 12, 2012 12:47 am
by corrado
You need to draw it through by tightening the nut, adding washers, spacers, etc as you go along. It takes a while as you have to keep removing the nut to add more washers. You'll probably knacker the threads doing it so you'll need at least a new nut, if not a new bar.
Posted: Thu Apr 12, 2012 7:19 am
by servetakid
Sorted it, the bolt was too tight on the mounts and the cones were worn.
