Starting to build my motor this morning. Problem, my rear hub bearing (brand new CASA bearing) fits right in the case with finger pressure!!! In and out! I did a quick measurement and get 2.025", I also have on hand a brand new JBL from India, it measures roughly 2.045" and also an old but in great shape Innocenti bearing and it measures about the same, 2.045"! So this is a TS1 and therefore would like a good quality bearing in there!!! I'm thinking that with a little gasket maker around the casa bearing inserted I'll be ok, because the seal plates hold it in place anyway.
Thoughts?
bearing/motorbuild problems!
WINTERMODEL150
- registered user
- Main scooter: lambretta ld auto
- Contact:
Hi,these bearings should be a nice tight fit ,i usually warm the casing up and drop them in place,if the bearings you have don't fit then try to find a bearing that does.Robi D wrote:Starting to build my motor this morning. Problem, my rear hub bearing (brand new CASA bearing) fits right in the case with finger pressure!!! In and out! I did a quick measurement and get 2.025", I also have on hand a brand new JBL from India, it measures roughly 2.045" and also an old but in great shape Innocenti bearing and it measures about the same, 2.045"! So this is a TS1 and therefore would like a good quality bearing in there!!! I'm thinking that with a little gasket maker around the casa bearing inserted I'll be ok, because the seal plates hold it in place anyway.
Thoughts?
You may have a warn casing but that's unlikely its normally the bearing that the wrong size,hope this helps.
Dean
tomdavid1988
- registered user
- Contact:
Had this bearing with CASA bearings, and heard a few others have too
Don't put in a s**t one just because it's to hand.
its often better to use a 40 odd year old innocenti one and just replace seals , issues like you discribe and also problems with shimming of gearbox and binding
bristolmod
- registered user
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
- Contact:
agree with Ricspeed- newer ain't always (ever??) better!
If the original Innocenti bearing is good, I'd be inclined to go with that rather than risk a part that has had "size" problems in the past.
Chris
Chris
Scootering since 1968.
Robi D
- registered user
- Contact:
As a follow-up on this, I did use the CASA bearing and used a smear of gasket maker on it. It was then a right b@5t@rd to fit in!!! So I'm more then sure it will work just as intended. The problem I have with using an old inno bearing is that while I think it looks fine and I do not find that is has any side to side play etc., I'm no expert!!
Thanks
Thanks
psychedelicropcircle
- registered user
- Main scooter: Series 1 li150 1958
- Contact:
Sometimes this can happen if the case has been sandblasted a little to much..I had the same problem and used loktite bearing retainer.
Robi D
- registered user
- Contact:
This case and cover had certainly been sandblasted by the previous owner. And I'd firmly believe with my experience of sandblasting, these were done a touch too much and with a far too coarse of grit!!! But they were still very usable.
- Information
Who is online
Users browsing this forum: Amazon [Bot], Google Adsense [Bot] and 2 guests
