Vespa carb gasket Quiz
Suede Ed
Main scooter: SIL GP200
Hello, the used gasket in the pic is from my '86 px200efl (autolube,of course) the new gaskets were ordered as a replacement, obviously they aren't correct, could anyone ID the new ones? and point me in the direction of a correct new one? Thanks for looking....
vesbrettas
th round ones are normally t5 not p2, the hole in the p2 carb box is slightly out of round and the gasket sould match that
gaz_powell
they can be used - from top to bottom
1. top one is carb to carb box (auto lube and non autolube)
2. next one is carb box to engine casing (non autolube)
3. next one is orignal carb to carb box (original number 1 probably genuine or from a good replacement gasket set)
4. bottom one is carb box to engine casing autolube
pattern gasket sets are often a bit universal
