Knocking??
Posted: Fri Apr 06, 2012 11:36 am
by junkyard
Got a knocking sound coming from my scoot when i push it backwards or fowards,i think its coming from the gearbox!Any ideas on the cause and how to sort it please,its quite loud but more so when pushing it backwards?
Re: Knocking??
Posted: Fri Apr 06, 2012 12:02 pm
by joeswoonara
i think the only way to sort it out would be to take a look inside .........don`t think that was the answer you wanted to hear ...........but a knocking could be a thousand and one things
Re: Knocking??
Posted: Fri Apr 06, 2012 12:06 pm
by goldeneye
can you make the noise so we can have a better idea...e.g. crash /bang/wallop.
Re: Knocking??
Posted: Fri Apr 06, 2012 1:13 pm
by junkyard
It sounds like If you were holding a layshaft in you hands complete with gears and selector, and you twist the layshaft back and fourth,The knock/donk sound you would get from the gears/gear hitting the seletor?
not sure if that makes any sense to anyone?
Re: Knocking??
Posted: Fri Apr 06, 2012 1:39 pm
by goldeneye
so it"s a donk eh. :lol:
Re: Knocking??
Posted: Fri Apr 06, 2012 1:43 pm
by Muppet
might be time to stop listening and start looking inside; i heard a crash bang wallop noise in my motor which rapidly tuned into a whack snap crunching sound followed by a imediate sort of OOuchhh noise as i skided to a halt; want anything serious only crank barrel piston head pot flywheel stator and crankcase needed replacing when the rod snapped and went out through the crankase demolishing everything except the gearbox and sprockets,
keep listening; muppet,
Re: Knocking??
Posted: Fri Apr 06, 2012 1:57 pm
by bristolmod
is there any gear oil in the crank case??
If not could be the gears meshing dry.
Or possibly the kick start ratchet just catching on 1st gear
Re: Knocking??
Posted: Fri Apr 06, 2012 5:17 pm
by junkyard
Yep, got oil in the motor,oh well time to strip it and ave a gander,cheers anyway.
