Knocking??
junkyard
Main scooter: SX230 TS1
Got a knocking sound coming from my scoot when i push it backwards or fowards,i think its coming from the gearbox!Any ideas on the cause and how to sort it please,its quite loud but more so when pushing it backwards?
Anytime you have a 50-50 chance of getting something right, there`s a 90% probability you`ll get it wrong.
joeswoonara
Main scooter: jet ts1
i think the only way to sort it out would be to take a look inside .........don`t think that was the answer you wanted to hear ...........but a knocking could be a thousand and one things
goldeneye
can you make the noise so we can have a better idea...e.g. crash /bang/wallop.
junkyard
It sounds like If you were holding a layshaft in you hands complete with gears and selector, and you twist the layshaft back and fourth,The knock/donk sound you would get from the gears/gear hitting the seletor?
not sure if that makes any sense to anyone?
goldeneye
so it"s a donk eh. :lol:
Muppet
might be time to stop listening and start looking inside; i heard a crash bang wallop noise in my motor which rapidly tuned into a whack snap crunching sound followed by a imediate sort of OOuchhh noise as i skided to a halt; want anything serious only crank barrel piston head pot flywheel stator and crankcase needed replacing when the rod snapped and went out through the crankase demolishing everything except the gearbox and sprockets,
keep listening; muppet,
C’est la vie
bristolmod
is there any gear oil in the crank case??
If not could be the gears meshing dry.
Or possibly the kick start ratchet just catching on 1st gear
Chris
Scootering since 1968.
junkyard
Yep, got oil in the motor,oh well time to strip it and ave a gander,cheers anyway.
