single saddle seats
Daggs
Hi, i know this is a bit anorak, but i'm keen to get it right. Series 3 Li 150 1963 originally fitted with twin saddle seats.
I'm fairly confident the seat wedges i have, go under the rear saddle. But i'm not confident which of the two is the rear seat.
One has a cut-out at the front of the seat baseplate (the part that bolts down onto the frame loop) The other has a baseplate with a frontal section. (i hope someone understands this)
Does the seat with the cutout go on the front? It seems likely to be this way to me. But i'm not SURE.
Supereibar
my question might sound stupid for you, but, does the front seat in your scoot has a seat latch?
bicboy
Main scooter: S2, EID Built, Diablo tuned...
I think the one with the cut out is for the front, so it dosn't restrict air flow to the air scoop ;)
Everything must be done to the Extreme.....
Daggs
Supereibar wrote:my question might sound stupid for you, but, does the front seat in your scoot has a seat latch?
No....But i am referring to single saddles
Daggs
bicboy wrote:I think the one with the cut out is for the front, so it dosn't restrict air flow to the air scoop ;)
Yeh! cheers Bicboy, that was my train of thought. They're going on that way.
diesel
Whatever way you put them on Daggs you will need an arse transplant after covering any sort of distance on them,They are fine for about town but after a heap of miles comfy they aint.
